I generally use tinned lugs because of corrosion resistance
Exposed as "In your engine area" where it is exposed to water, air, humidity, heat. If you're so concerned about corrosion...get a gold one. lol
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
That's one of the ideas behind the tinning, copper likes to corrode. You can use straight copper on aluminum, but yeah leave it one for a year and she'll be fused right together from corrosion. Had that problem whit my engine block ground :shrug:
2015 Subaru Outback. That is all, I refuse to touch it.
I did order 40 tinned copper lugs. Now if they are tinned, can they be used on an aluminum buss bar? i know aluminum don't like copper.
Galvanic corrosion FTW <_<
Easy way around that: put some dielectric grease in-between the copper lug and aluminum buss bar. It will seal out water/moisture (which is what acts as an electrolyte, allowing the corrosion to take place). Worked fine for me so far :)
How's does aluminum not like copper...? I use them together all the time..the gold connectors are brass a shitty conductor..zinc is better than brass..just check exposed lugs in engine bay or on frame frequently for rust
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Well..mechman uses copper for their products, you'll see a lot of people using copper. I'm not going to recommend anything..cuz I'm pretty sure someone will flame my ass for saying my opinion.
ill do it! lol. the tin is just a coating to protect the terminal from corroding. the lug is still all made of copper.
...............................so even tinned they will still corrode on aluminum? Might just get some copper bars instead then. and doesn't dieelectric grease prevent conduction? like electrical tape? thought i heard that before, could be mistaken. :ughdunno:
  • Who's Online   0 Members, 0 Anonymous, 1475 Guests (See full list)
