MrSkippyJ Posted April 17, 2012 Report Share Posted April 17, 2012 How does a monoblock amp use the inputs? Most monoblocks have a L/R and of course most sub outputs are mono. My 3sixty has a single sub output, but my amp has the normal L/R inputs. I obviously use a Y-splitter to take care of this, but my question is am I only getting 1/2 my RCA voltage to my sub amp? I know it doesn't really make a difference I just didn't know the answer and it is one of those things that I wanted to know. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
OrionStang Posted April 17, 2012 Report Share Posted April 17, 2012 Measure with dmm and let us know? Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 17, 2012 Report Share Posted April 17, 2012 Yes, it makes a difference, 1 RCA is half the input signal as 2 rcas. But if you have a strong input signal in the first place, that shouldn't make a difference. With 5v outputs from the 3sixty, you should be fine Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Noobtastic14 Posted April 17, 2012 Report Share Posted April 17, 2012 The voltage is supplied by the source not determined by how many RCAs you have. That RF will give you good signal and on monoblocks the inputs/outputs are internally in Parallel so it doesn't matter if you have one RCA or two sets of speaker outs. Either way within the amp it is all the same. -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 17, 2012 Author Report Share Posted April 17, 2012 (edited) well, i don't have my car atm, it's in a shop being fixed. but even with that, how would I be able to tell what voltage the amp is receiving? I know the RCA outs on the 3sixty are 5v so the sub out would also be 5v. When you split RCAs for 2 amps, you divide the voltage. What is confusing is this is being split to a single amp. Assuming I had L/R sub outs that were 5v you would assume that each L/R input of the amp gets 5v. They way I have to do it is I split a single 5v signal, but to the same amp. Again, I know it doesn't really matter, I'm just curious. got some ninja responses. Thanks guys Ok so they are parallelled internally. Makes sense now. I knew that I had plenty of source voltage, I just wasn't sure how it worked. Edited April 17, 2012 by MrSkippyJ Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
cheese20323 Posted April 17, 2012 Report Share Posted April 17, 2012 and the gain is for your RCA voltage if you put it all the way up its like if you have .2v rcas in between is like 2~~3v just adjust gains accordingly Quote 92 Accord Build Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 17, 2012 Report Share Posted April 17, 2012 The voltage is supplied by the source not determined by how many RCAs you have. That RF will give you good signal and on monoblocks the inputs/outputs are internally in Parallel so it doesn't matter if you have one RCA or two sets of speaker outs. Either way within the amp it is all the same. -Drew Then why is it that if I unplug an RCA on my amp, it gets quite a bit quieter? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Noobtastic14 Posted April 17, 2012 Report Share Posted April 17, 2012 INTERNALLY IN PARALLEL. the source is still the same. 5v is 5v whether it is going through two lines or 10 as long as a single line can carry the 5v it will still be 5v. You are not losing anything going with one run. -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 17, 2012 Author Report Share Posted April 17, 2012 and the gain is for your RCA voltage if you put it all the way up its like if you have .2v rcas in between is like 2~~3v just adjust gains accordingly Yeah, I knew how that part worked too. I was just curious how the monoblock amp treated the inputs. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Noobtastic14 Posted April 17, 2012 Report Share Posted April 17, 2012 The voltage is supplied by the source not determined by how many RCAs you have. That RF will give you good signal and on monoblocks the inputs/outputs are internally in Parallel so it doesn't matter if you have one RCA or two sets of speaker outs. Either way within the amp it is all the same. -Drew Then why is it that if I unplug an RCA on my amp, it gets quite a bit quieter? In this case your single RCA can't carry the load so the second one is actually helping. As long as the wire can carry the load additional runs won't make much of a difference. -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew Link to comment Share on other sites More sharing options...
