Trey_Dog650 Posted April 21, 2012 Report Posted April 21, 2012 where are you checking your voltage at? batt or alt? 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
max.krupski Posted April 21, 2012 Author Report Posted April 21, 2012 where are you checking your voltage at? batt or alt? well last time it was just through the in dash voltmeter but before it was at both alt and battery with a volt meter. its so f'ed up how now it works now??
max.krupski Posted April 21, 2012 Author Report Posted April 21, 2012 come on guys i need some answers what the hell is going on here??
matt@mechman Posted April 22, 2012 Report Posted April 22, 2012 You can run your vehicle off the battery if you want, just bring a battery charger with you to work so you can charge it while you are at work. Just keep in mind, that your vehicle could shut off at any time if your battery becomes depleted- which could put you in an unsafe situation. I know several SPL competitors in CRX's that have multiple 16 volt batteries in their vehicle, and do not even have an alternator on the car. They will drive sometimes several hundred miles to competitions, charging the batteries every hundred miles or so.
max.krupski Posted April 22, 2012 Author Report Posted April 22, 2012 You can run your vehicle off the battery if you want, just bring a battery charger with you to work so you can charge it while you are at work. Just keep in mind, that your vehicle could shut off at any time if your battery becomes depleted- which could put you in an unsafe situation. I know several SPL competitors in CRX's that have multiple 16 volt batteries in their vehicle, and do not even have an alternator on the car. They will drive sometimes several hundred miles to competitions, charging the batteries every hundred miles or so. Ok thats good to know but I was wondering if you knew what going on with my alt cause now it's working fine again?
max.krupski Posted April 22, 2012 Author Report Posted April 22, 2012 Bad ground Where!!?? Lol this is driving me nuts
EclipseChris Posted April 22, 2012 Report Posted April 22, 2012 Do not drive a 2010 vehicle off of battery power alone. Ever. That stuff used to fly like 20 years ago, but not anymore. Your complaining about a lil over 2 hours of labor for an alt, just imagine how much it'll cost to put an ecu and entire wire harness into it. To answer your question... Does your alt work? If yes, then whats the problem? If no, just replace it. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
