ok i got my two dual 1 BTL's wired to .5 ohm on a MMATS 3500.05 and it get loud but is (out of sync) almost seems.. on low notes it is bad! almost seems to be popping back and forth. any suggestions?? thanks! and even when i turn the amp down it does it after turning the volume up.
One of your subs is wired backwards. Either that or one of em is dead and acting as a passive radiator.
We have a bigger problem. You can't wire two dual 1 ohm subs to .5 ohms... Hope you're not actually wired at .25.
Edited by LZTYBRN
*dual 2's my fault. and no its not continuing to play after, the subs are just off beat, even when i wired it to 2 ohms.. but they didnt do this with my Alpine mrp-2000 amp (with the subs wired at 2 ohms). it did this right after i put the new MMATS on them
Like there not hitting right went they should be? Or there hitting opposite of each other?
"The only man who makes no mistakes is the man who never does anything" -Theodore Roosevelt
do you have the subs wired together?
like this
or like this
Edit: Sorry it's a mono amp so i take it its wired like the first one
Edited by TrentonLong
  • Who's Online   0 Members, 0 Anonymous, 499 Guests (See full list)
