I have 4 brutus 2608s and a maxxlink that ive been running 3yrs now....getting bored with the setup
and 4 Dual 2 subs
Heres my evil plan....
I have the amps strapped and the manual says to not run them below 2ohms while strapped...well i know for sure they can as ive ran them at 0.5 each but not strapped
I want to run all 4 subs wired into 1ohm total > into all 4 amps that are strapped 2x2....
to make things simple i tried to make a drawing with an online paint hope yall can see where im getting at
basically one voicecoil at 1ohm (scratch that 0.5ohm i metioned in the pic).... 4 amps 2 pairs strapped into 1 coil thats 1ohm_
just wondering would the 2 added amps feed back into the first two?
would the 1 ohm load split across all 4 amps?
....what problems could i be getting into doing this?...
also i have jumper wires going from the (-) on the master into the (-) on the slave of each linked pair___ should i jump a wire from the other linked pairs (-) into the first when attempting this or leave them be and run 2 strapped pairs into virtually 1 coil???
@DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many
-TEAM WOBBLY WOOFERS-
4 18s MAKE YOU SCREAM!
Hmm, I think each amp would be seing .25 that way. But hey, with the maxx link, it just may still do it....
Let us know how it turns out.
But remember, if you do try it, your risking something getting fried. So is the risk worth the reward?
Btw if it were me, I'd probably try it too. I'd just be extra super careful.
And IMHO I believe they will protect. But hey, I wish you luck!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Posted (edited)
so, before i help you blow your subs and amps..
whats your electrical like to be running over 10k?
and what subs are you running?
dual voice coil?
single voice coil?
2 ohm DVC?
4 ohm DVC?
2 ohm SVC?
4 ohm SVC?
Edited by Sheena
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
dual voice coil?
single voice coil?
2 ohm DVC?
4 ohm DVC?
2 ohm SVC?
4 ohm SVC?
i believe he says "4 dual 2 subs" in the first paragraph...
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Posted (edited)
he actually says 4 Dual 2 subs.. (how many subs does he have? 4? 4 Dual 2 ohm?)
Dual is a brand.
need more information.
thanks for your input though. it helps quite a bit. not.
although, 4 two ohm DVC subs can be wired to 1 ohm, i still think Dual is suspiciously capitalized.
Edited by Sheena
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
really going to attack me cause i asked questions to the OP?
never said hes running Dual subs, just said its suspiciously capitalized.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I dont see this working out well at all. OP read up on strapping your amps.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i have them strapped right now 2 subs per linked pair ... used to be 1 sub per amp
4 hdc318s
1 300 amp iraggi alt (just found out about a sense wire and ran one to the battery (+) post last night with a 1a 200v diode inline
4 2608 brutus amps
one maxxlink
and one lil shuriken bt-100 thats been going strong for 3 yrs I just put bigger terminal screws on it and car went dead (battery probably never was getting charged as i had 6 0 gauges rigged on top each post)
ive had this set up for three years...wanting to try something different
I reconed 2 months ago used epoxy under and above the spider landing...I shortened my 38 hz port down to 34 hz (more excursion and im loving it) the epoxy i used during recone is holding up alot better than CA glue so far ...i think i can throw more power at em I know how to watch for clipping....
  • Who's Online   0 Members, 0 Anonymous, 1228 Guests (See full list)
