ok so i got a soundstream rub1.2500 and i have a fi btl 2 ohm wired to 1 ohm. latley my amp gets REALLY hot and then shuts down, after a while it turns back on.
my question is why? if its a 1 ohm stable amp
Nobody can shed any light on my question?
From what I know those are only 2ohm steady
2001 Ford Expedition
2 SA 12's
Crescendo 2000
M.E.C.A. 141.4 DB
my bad, Chevyboy95, I dont have one of those amps just have a buddy with one and thought he said it was 2ohm..... and noser7 he is saying that it can go into thermal protect because the temp in your area so what city and state are you in
2 SA 12's
Crescendo 2000
M.E.C.A. 141.4 DB
2 SA 12's
Crescendo 2000
M.E.C.A. 141.4 DB
sounds like voltage drop what is your electrical like 2500 is way over most stock alternators a good amp does a descent bandage but big 3 will work wonders for the time being also a bigger alternator will help
also what the volume at --/max
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Check grounds and connections? Poor voltage at the amp because of bad connections will certainly make it clip/heat up
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
