is this box right calculated?
Troopzz
Also if the port is in the bottom you need to set the "# of common walls to 1, and the baffle thickness is blank, and you would probably consider bracing and/ or a double baffle.
baffle thickness is ok to be blank, as that's referring to extra baffles. although if he were to add more (which i also recommend) then that field needs to be filled in
do a single chamber, you can still use 2 ports if you must, but a single chamber will help, and a single port has been known to outperform multiple.
  • Who's Online   0 Members, 0 Anonymous, 699 Guests (See full list)
