5/16 SS all thread for the speakerwire - yeah its a bit overkill.
cut to a bit over 2" pieces
waalaa!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Mounting board.
As you can see by the shadows in this one its getting late in the day.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Grinding down some sharp corners and protruding screws.
That's all for now, stay tuned!!
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Up late tonight working my box wiring for the subs.
Just getting started here:
This should be somewhere around 1-1.4ohm :
This should drop it down to .25 - .35 ohms:
That is all...good night !!
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Lol at the terminals for the woofers, any serious bass head has to have access to all the coils at all times with out pulling the woofers! Lmao!!! 60lbs+ woofers SUCK to pull especially when they are not facing up lol. I would love to own a mt motor again. they were my first BEEFY woofer. Looking forward to some vids sir!
On 2/27/2013 at 9:21 AM, Swordlordboy1234 said:
Who needs electrical! It's a bc3500... They make power out of hopes and dreams of children
1990 Oldsmobile  Cuttlas Cruiser- New build coming soon!!B47FCE3C-8667-408C-8884-8393C4DAE824-1875-000002C58366462A.jpg
I dont have access to mine at all times .I guess Im a poser.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thats ok because your build is pretty;) lmao!!
  • 1 month later...
Sorry for the delay, Early May I took a trip to India so had to come back, rest and now I'm sorta back to normal (whatever that is). OK some recent small updates.
Going to use allen head 1/4 x 20 bolts to hold the woofers in.
Well, the bolt heads are too big for the hole in the rubber gasket and the subs will be countersunk so there isnt much room to peel them back. Also, its a big head so need room in the gasket for them.
Here is the goal.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
First I found a drill bit that was just a little bit larger than the head of the bolt.
Then I drilled it out.
Here is a video of the drilling action:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
