help with port tuneing
OK so i designed my box to be tuned at 33hz with 2 4in aero's at 20in long and it plays the higher notes with authority but not the low notes what im thinking is my tuning is off as the ports come out of the box 12in and the other 8in is in the box would that effect it any or would it still have the same tuning the subs im running are 2 dc lvl 2 12's they are brand new just got them yesterday and i went with dc's recommend box size from there site here are the box specs boxdone.jpg any help is appreciated
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
Yes it would, see the box titled external port length? Adjust the numbers so it represnts what your box is.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
ok i must of over looked that box it brought it down to 32hz which is fine i like the lows but it don't hit them lows with authority could it be there still brand new and don't have even 30 min's playtime on them so there not broken in yet
2000 Eclipse
I just built this for my lvl 3 12s and it hits harder then ever
http://i15.photobuck...evinss/box5.png
that box specs look prety good but you have lvl 3 and mine are lvl 2
2000 Eclipse
What is your port area per foot with the updates external port? For Aero ports the general rule is 10-12, if you want the lows try and get closer to the 12. Another thing like you said, since they are brand new, the suspension might be a bit stiff, making it hard to drive them.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
its close to 10 its at 9.55 but with my old subs the port per foot was only like 5 same style box just bigger cubes and it hit the lows great so i'm leaning towards that there still brand new
2000 Eclipse
Isn't you net volume a bit small for bottom end on 2 12s?
2.43 on the original post
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
the box size is about right on, but what do you have your subsonicfilter set to?
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Port are per foot of 5?! and it slammed the lows? I don't know man, I have heard that come from people on here who do amazing work with stuff and I put a lot of confidience in their knowledge. 10-12 for aero ports, and 12-16 for slot port, and if you want better low end, build slightly bigger than recommended volume to.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
