Road to 150+ with single 15.
Good luck with the setup! I have no doubt that it is possible to have a single 15 hit 150dB. Wasn't there a guy who got a single 18 that could hit 180+dB couple of years ago? If he could do that, you could do that too!
EDIT: Here's a link to a guy who got a single 18 hitting 180db in case if you're curious!
[link]
You didn't really say that did you?!?! Where are you getting this info, I HOPE you're joking and I missed it....
*Edit-Was this done on a TL?
No idea, man. I tried to search more information about how he do that and what kind of mic it was tested on but no luck. Can anyone else confirm this?
I guess he was talking about how it's an extreme comp car, bolted everywhere probably. While mine is a street class car and nowhere near that level, lol. But that's ok! I know with a lot of work....i'll eventually get up there with all my testing. Maybe not this year.....maybe not next but I see a ton of people, like tommyk, hitting 150 with a single 10 without a sweat but other people with the same vehicle or even simliar trucks, needing tons of power or a lot of cone area to get anywhere close. Why? Cause he's put in a ton of work. Go onto Ca.com and look at his threads and posts years ago, he was only hitting 135 db a decade ago. He put in a ton of work, Hitting what? 154 with a single 10 now?
I'll get there;) But for now, my magic box is retiring, cracked the second baffle off......motor force...ftw? Lol.
'11, '12, '13, and '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca Street 2 World Finals - 3rd Place(148.7)
2013 Meca Street 2 World Finals - 2nd Place(151.1)
  • 2 months later...
I dialed it back a couple notches. Put in my hdc3 wired at 1 ohm. Clamping ~1200 watts. That's my set up while I fix up my car and try deadening and other stuff. So far, it's up to 146.1 @headrest. And like 147.5 in the kick. Not bad numbers for the watts and single 15. Wait till I drop in another sub and drop to .5 ohms.
I threw in my sundown z v.3 d1 to see what it does. Hit a 148. unofficially though.
  • 8 months later...
Came across my own thread, I can add some more info.
Placed 3rd at meca world finals in street 2. Scored a 148.7.
Haven't worked on it much this year but unofficially up at 149.3.
Single sundown z v.3 15 on a dd m3a. I can add more power or put the meter in the kick, both will put me into 150's but this is my street 2 set up so i'm sticking with what I got.
Here is a link to a build that I did off similar power in my Focus. All metering was done on the dash with the car sealed so I could see some improvement with windows open in your case. The vehicle that you have is very good for spl and I'm sure you will get loud soon enough.
http://www.stevemeadedesigns.com/board/topic/52678-small-spl-build-for-my-zx3-with-numbers/?hl=+nightshade
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Getting pretty close to the goal David! Have you try resin the box?
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Haha you were the guy that knocked us out of qualifying last year. I have to say I did not expect the numbers you did
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
street 2 in meca might be a tad interesting this year
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Hopefully all the street classes are good this year.
I moved up to street 5.
Team B2, Team Audiotechnix, Team Kicker, Team XS Power, Team Sundown, Team Maxxsonics, Team DD2008 Bassrace 130-139.9 Regional and National Champion2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, S2, S3, S4, DB1) -1 DD 9510F + 2 Sundown SAZ2500's @ .7 ohm strapped=154.2 headrest, 129.2 driveby-2 DD 9510F's + 2 Sundown SAZ2500's @ 1 ohm strapped=154.0 headrest-1 DD 9512F + 2 Sundown SAZ2500's @ 1 ohm strapped=153.5 headrest, 131.1 Driveby
-2 DD 9512F + 2 B2 Zero1's @ .5 strapped= 157.0 headrest, 158.0 outlaw-1 Sundown SA-8 + 2 MB Quart 2000's=148.8 headrest, 150.6 outlaw
