Omega5002 Posted April 10, 2013 Author Report Share Posted April 10, 2013 Get the map gas torch not propane Will do Rick and Colton94 mentioned it works a lot better than a Propane torch for soldering wires for sure, so I'll get it when I need to solder my wires . 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
HatersGonnaHate Posted April 11, 2013 Report Share Posted April 11, 2013 X2 on the map gas. Burns hotter than propane, works wonders on solder joints. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car. Link to comment Share on other sites More sharing options...
Omega5002 Posted April 12, 2013 Author Report Share Posted April 12, 2013 Well, finally hooked everything up, though sadly, my RE DTS1500 went bad on me, when I hook it up, it goes into protect, then blows the power wire fuse, so gonna have to save up for a new amp, and at the meantime, borrowed my friend's MB Quart FX1.600(which used to be mine lol), and ran it at 1 ohm(2 ohm stable), doesn't get very hot, actually less hot then when I used to run it on a shitty ground. Noise from the 4 channel is gone too, so hopefully that's a sign of a good ground as well, though voltmeter is dead, so need a new one as well.Anyways, the new box is much louder than my CVR12 on 900 rms, also hits harder, tighter, faster, and goes lower without sacrificing the higher bass, actually, the higher bass is also just as painful lolThis is on a cheap $90 amp too And here's some pics(need to clean up the wiring, I know)Also touched up the box a bitVideo will be soon, battery needs to charge on the camera, and have to find a place to video. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
Omega5002 Posted April 12, 2013 Author Report Share Posted April 12, 2013 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
Wicks Posted April 12, 2013 Report Share Posted April 12, 2013 Dude, that was a decent idea on the heatshrink around the wire at the sub terminals. I DAMN near pulled my hair out when I tried stuffing 8ga wire into the terminals on my Skar VVX12's that I used for a bit. Those terminals may say 8ga but sure as shit don't fit 8ga. Heatshrinking around the frayed wire was a good choice. I've seen plenty of people just leave it and then complain later when enough of the wire shorts out and damages the amp. That's one of the main reason's I got my XL12's with direct leads. Here's a handy terminal that I wish I bought before I messed with those terminals: http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1075 You may be able to find other cheaper options but that should help save a headache to two. There even stack-able to make it real easy to series/parallel extra subs or coils. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
Omega5002 Posted April 12, 2013 Author Report Share Posted April 12, 2013 Dude, that was a decent idea on the heatshrink around the wire at the sub terminals. I DAMN near pulled my hair out when I tried stuffing 8ga wire into the terminals on my Skar VVX12's that I used for a bit. Those terminals may say 8ga but sure as shit don't fit 8ga. Heatshrinking around the frayed wire was a good choice. I've seen plenty of people just leave it and then complain later when enough of the wire shorts out and damages the amp. That's one of the main reason's I got my XL12's with direct leads. Here's a handy terminal that I wish I bought before I messed with those terminals: http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1075 You may be able to find other cheaper options but that should help save a headache to two. There even stack-able to make it real easy to series/parallel extra subs or coils. Thank you Wicks Those should work very well when dealing with over sized wire for sure 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
scooter99 Posted April 13, 2013 Report Share Posted April 13, 2013 Looks like it gets down pretty good man! Nice work! Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
Omega5002 Posted April 13, 2013 Author Report Share Posted April 13, 2013 Looks like it gets down pretty good man! Nice work! Thanks Scott Can't wait to add more power 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
scooter99 Posted April 13, 2013 Report Share Posted April 13, 2013 Cough nendo bc2000d cough probably find one in the classifieds around here for a decent price. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
Omega5002 Posted April 13, 2013 Author Report Share Posted April 13, 2013 Cough nendo bc2000d cough probably find one in the classifieds around here for a decent price. Lol, I wish(one day though) Would need a good battery bank in the back for that though 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
