5.0 Bassrace Build (new Vid Pg. 6)
looking good so far!!!if it was me,i would add another 1400 in back.
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
yea bro, ask christian what happens when you ground the amps really good. (it gets louder lol)
looking good bro, I agree with nismo for once add a second batt in the back that t3000 will thank you for it.
ill def add another 1400. i knew i should had went bigger. overkill is a must. ill see if i can get by with this one at autorama for now.
going to get out there today and work on it alittle. some amp rack work, finish running 0 gauge and double double check wiring.
start the box build first thing in the morning.
GROUND EVERYTHING PROPERLY, you will thank me for it. I gained 1.5-2 db by grounding everything solid. Use bolts that go through to the other side of the metal, and make absolutely sure you get clean BARE metal. If you are unsure, it should look VERY shiny SILVER. IT will be well work your extra time and effort, and the results will speak for themselves. Just take your time, Can't wait to hear it.
Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
Guest Nismofreak
better thing to do...1 run of 0 guage wire to back of the battery to get a direct connection and much better connection mostly
ps got fi: didn't notice your box will be tunned to 35hz....around a 147db you could get out...good luck
after placing the batt and amp, it was time to connect all + and - in place.
im not tring to build my bassracer all pretty and clean. its not for show, just comps.
heres what i got installed today. box build tomorrow. Posted ImagePosted ImagePosted Image
Looks great so far but definately put another battery in the back. Out of experience I found the t3000 will thank you for it!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
very clean install bro. you can always build something out of wood and cover that amp battery up ......... throw a lil carpet over and VOILA ....... the battery has disappeared. looks good though man ....... i'm loving the 5.0 period and for you to throw some nice bang in there makes it all the better.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
