Question about the DD-1.
Weird. I plugged a 3ft RCA from the shop directly into the front out and got the same.
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Yes it is on. I plugged a 3ft RCA into the front speaker preout on the radio. I am playing the 1khz tone and it doesn't pick up the signal till 30 out of 35 and it says it distorts at 34 out of 35.
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
OK so what's the problem, then
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
he probably expects a signal light at volume 1. doesn't realize that practically every headunit has an exponential volume increase
Well I didn't think that it would be that high out of a distorted volume.
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
I expected the signal light to come on at less volume than 27. I also didn't expect the highest undistorted volume to be one away from the highest
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
dude look in the troubleshooting of the manual it says something like your head unit doesnt have enough output power for the dd-1 to detect signal you have to follow the directions to set it through the amp i lost my manual but it says something like turn your gain on the amp all the way down sub sonic down lpf up set everything on the head unit flat ground the dd-1 put the positive probe on the speaker outputs and start turning your head unit up. dont forget to disconnect the speakers
  • Who's Online   0 Members, 0 Anonymous, 1208 Guests (See full list)
