wow epic ...
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
You mean like running a dual alt setup with this and the stock one?
The only way I see would be making a custom bracket for it or swapping out the case
^^^^ this. Run a dual set-up with a custom bracket. Bypass your pcm with a toggle switch to manually turn the alt on and off.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
Dude this is so clean. I wish I was that good at wood working. You make me wanna do a blow through. But there is no way I could figure out all those angles! haha. Ill get there. Lookin great man
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
That box is a beast!
MY BUILD LOG: http://www.stevemeadedesigns.com/board/topic/146568-late-80s-ibiza-build-log-2-15-in-954-cu-ft-eu/
JVC KD-R801 Head unit
6 x Zacks CMR 165.2MKIIIB (6.5")
2 x Zacks PTW 345 tweeters (5" aluminum horn)
2 x Zacks PTW 445 supertweeters (10.6" classic horn)
1 x JBL GTO 14001E D Class
1 x JBL GTO 1400 A/B Class
2 x Zacks Race 100.15 subwoofers
1 x FAM Supernova 120Ah AGM battery
This thing looks awesome! Great craftsmanship for sure.
You may have already mentioned it and I missed it, but with the tunnel being so long do you plan on running multiple amps to correct phasing for the subs at different distances throughout the tunnel?
Team NorthWestSPL
