Not sure what kind of crossovers are on the rockfords but sundown has a pretty sweet crossover setup on their amps. Might wanna check them out. Should be able to run everything you want with them. Might be able to get away with one sax-200.4 depending on your power needs and ohm loads.
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
The thing is though, for the woofers I need to run high pass and low pass, but a T400 and T600 don't have both availbile to a single channel.
Edit: Didn't see the 3 others that you guys posted, will check all them out.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
How about an AQ 120.4? Has BP crossover options and a range of 20hz to 5khz.
Thanks bro, That AQ120.4 is real nice looking, and way cheaper than the RF. Think I will just pick up 2 when I do it and just run active from the get go since the T600.4 is around 500, 2 of these is around 600.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • 1 month later...
I'm actually doing a setup just like this right now and I'm running into the same problem with the active crossover. I don't want to use passive as they change impedance and decrease power output to speakers. For under a 100 dollars there is a clarion 4eqs or something like that. For bandpass on the mids I was thinking u can run the rear channels on hot at like 100 Hz on the active crossover and do a low pass on the amp set to the 500 Hz or vice versa. The only problem Im having is trying to find a way to keep my fading and balance because that clarion will turn ur front rcas into tweeters and rear rcas for mids. My setup is two t400-4 and 8 tweets and 8 mids, they are t1 components.
Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car
  • Who's Online   0 Members, 0 Anonymous, 541 Guests (See full list)
