so if you are makeing a turn with a port u would add add half of the size of what the port is? is this write or em i wrong
(example if my port is 4 inchs i would add 2 inchs to it when it turns and 2 inches to it when it turns up)
if you were to measure down the inside of the port, the effective port length would be shorter. likewise, if you were to measure down the outside of the port, it would be longer. measuring down the middle of the width of the port gives you an accurate measurement.
So on your calculator the length you put in for the port would be the measurement down the middle of the port and the physical port length is the inside of the wall? Take a look at my forum please..
http://www.stevemeadedesigns.com/board/topic/142010-torres-box-tuning-calculator-design-help-15sp4/
149.4 Db @ 30Hz Outlaw With One 15" Fi Team Sub, Trunk Build. !!!!!Hair Tricks!!!!!
Check Out The Build Log http://www.stevemead...0-4-and-t400-4/
Watch The Videos http://www.youtube.com/user/jcplaya3
you are exactly correct
haha i like how you link to that thread, and that thread links to here lol
No it goes to a thread i started yesterday, i need help because i want to put 45's in the bend of the port for my box and i was wondering if it would change the calculations on you program like the tuning freq or the port area since the bend in the port is actually wider from the corner of the box to the corner of the port wall.
  • Who's Online   0 Members, 0 Anonymous, 1494 Guests (See full list)
