Crazy thoughts.. Would this be practical? Would be sweet though
Its good you are thinking of ideas.
The main drawbacks are these.
Magnetic woofer connections - Not a solid connection, current and voltage transfer capabilities would be on the low end. Susceptible to vibration and high power may induce arcing at connection which would create heat at connector.
Bluetooth amp signal input. - Bluetooth is basically a radio transmitter and receiver. Because of this, interference from outside sources is possible, signal to noise ratio is diminished from standard hard lines, signal voltage is limited, and frequency response is limited.
well poop
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Might want to rethink on the Bluetooth. Everything requires a hand shake to make a connection. Can you imaging what you could do with this technology. Picture everyone at a car show being able to use Bluetooth to connect to a server playing music. 50 cars with thousands of watts playing the exact same track. Would make for an awesome concert. :)
Bluetooth: Low Power and Low Cost!
Bluetooth wireless technology operates on an open frequency within the 2.4 gigahertz band, which is the same as WiFi, cordless phones and various other wireless devices. Bluetooth is able to share the same frequency band without experiencing any interference because it utilizes various key technologies.
One of the ways Bluetooth avoids interference is through the use of low power signals (around one milliwatt). Devices using the Bluetooth Core Specification Version 1.1 or later (To learn about the different Bluetooth versions, click: Bluetooth Core Specification Versions) are able to avoid interference with other wireless devices because their signal is so weak.
Take into consideration that powerful cell phones use a signal of around three watts. Even though the signal is weaker, Bluetooth still offers a range of up to 30 feet (Newer versions can have a range over 100 feet).
The signal is also capable of passing through the walls in your home, making it useful for controlling several devices in different rooms. Data can be transferred at a rate of up to one Megabyte per second (Mbps).
Also, because Bluetooth transmitters require minimal amounts of power, they are relatively inexpensive to manufacture. Simply put, Bluetooth uses low-power radio waves to reliably communicate in an inexpensive way.
Edited by Hotdog
Want to get rid of noise and resolution problems.
Just go optical all the way back.
Funny how far behind "most" car audio products are when related to the home side.
Not for bluetooth 3.0 + hs, that basically uses bluetooth for negotiation and establishment then the actual data is transferred over a 802.11 link.
Could be possible. Plus with speeds up to a theoretical 24 mbits/s you wouldn't have bandwidth issues.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
S/n = poop
its very easy to mess iwth blue tooth signals.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Ah. You know people. There will always be somebody who tries to fuck with other people's stuff and if not that then someone will cry tampering when they lose.
  • Who's Online   0 Members, 0 Anonymous, 1127 Guests (See full list)
