Lexus IS-F Sound System install - Custom SMD VM-1/OM-1/TM-1f Dash Piece (update page 71)
Hey man I'm confused on how you found the shapes for the panels. Could you maybe explain that?? Thanks!!
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
im not 100% sure but it looks like he gets cardboard and cuts it out until it shapes whatever the wood is going to be around than puts cut out cardboard on mdf and traces it out, this giving him the shape he needs for the panel to fit nice and perfect
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
[quote name=^_^ Gem132' timestamp='1338717730' post='2041498]
this ^^^ i cut the panel out of 1/8 or 1/4" mdf and "rough it in" Basically get a piece that is close, usually cut the 90deg angles to the correct size and then fill the gap left over with small pieces of cardboard. Tape them to the board until you are all the way around the area with the crazy shape. Then remove the template with the cardboard on it. It will be a little bit jagged but once you trace it out on a clean piece you should be able to clean it up and make a smooth cut.
There's other ways to do it but this way works best for me. I have tools that a meant to find shapes that don't work nearly as well as this.....for ME anyway :D
Follow my Tweet (Twitter)
ok guys, i have a confession to make. I was so excited about my trunk looking as good as it did, i failed to shut the trunk ALL the way before i took video, pics, and then took it all out and left for the day. The next day i put the side panels back in and then tried to shut the trunk. It only stopped short 8" LOL - WOOPS. The hinges do NOT hit, they pass through very smoothly.....but where the hinges attach to the trunk lid, it is really thick. I didn't pay attention. Anyway, the following pics are me averting disaster and re-doing them AGAIN. Hey, its days like this that can only make you better and sharpen your game! So it looks a little different but to me it looks just as good.
I started out by shedding a tear and throwing my hat across the shop. Then i notched out the side panel, dropped it down about 2.5" and completely re worked it from the ground up.
Heres how it was looking.....
this is what i had to do.
we have clearance, Clarence!! Disaster averted! :)
