How much port should this 4th order have?
BEEMDUB
I have no fourth order experience, but I can suggest using barbed insert nuts to attach the front piece so you can easily remove it anytime you need to access the subs. I've seen them used alot for removable ports. In fact, Steve Meade used them for the plexi on is isf box build.
Edit- actually they are called BARBED INSERT NUTS, not hurricane nuts.
I think I'm gonna use barbed insert nuts I don't see one of those comin out especially if use some glue to keep em in
Yea just put a dab of CA glue on em and I think you would be golden. And space em no more than 3" apart all the way around.
gotcha how exactly should I go about attaching the front of the box so that I will be able to remove it? heres how the front is now in my design
Start big, then shrink it.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Call the manufacturer and talk to the techncal support there, some of them are extremely helpful. Plus they can probably give you an answer in a couple minutes, forget emailing them, just call. To get the subs out you need a removable section of box to gain access. I guess you could double up one side and cut the inner sheet a little smaller of a hole so you could just screw on the panel.
3cuft??
Lol
Jesus.
Waste of time
no expert on 4th either
but ive always been told, built recommended sealed, then build what ever you want ported as long as its somewhere around recommended ported and youll be fine.
if you build 2 separate boxes you can use t-nut to join boxes like i have drawn
edit
forgot
2.2cuft sealed (1.1cuft each)
3.9cuft ported @ 42hz
Thats a great idea john.But where would you gain access to the t-nuts?
3cuft??
Lol
Jesus.
Waste of time
What?
edit
forgot
hmm thats an idea i actually thought of too seems like it would be a pain in the ass I was thinkin use a bunch of...*Edit* nvm lol L brackets wont work
  • Who's Online   0 Members, 0 Anonymous, 1606 Guests (See full list)
