hey guys,
I'm wondering if the gains on tweeters are set properly if I set my crossovers below 1k to use the dd1 but when playing music I have them at 10k?
4 way with a dead head.
thank you gentleman
my tweets (a-pillar) are set at 10k as are my 3 in midranges (kickpanel) because that's how I think it sounds best.
I thought I was setting it "full range" per instructions 'Setting the gain of a full range amplifier' in the manual?
Most tweets run 3.5k(some lower)and above.....you're losing output and have a BIG gap where you're not hearing things you should be.
not sure how that's possible when as I said my mid ranges I have playing up to 10k. Since said midranges are in my kick panels the 3k-10k range isn't so close to my face, hence, not so harsh. I'm still hearing those frequencies.
Thats very high for a midrange to play. I have 80Hz to 4000k playing through my mids and highpass at 4000k for the highs. Also you dont want the tweeters set with the dd-1 at the full gain position the dd-1 will show no distortion at. The tweeters will be overpowered most of the time unless you are using a small amp for your speakers but if you are using a large amp like i am for the mids and highs you will want to set the gain for the tweeters with the dd-1 first then play a song with a ton of treble to it and turn the gain down until the tweeters stop making like a hissing noise when cymbals are struck or anything high frequency like that. But your x-overs are setup completely wrong thats for sure.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
You guys don't seem to read very well. He's running a 4 way set up. Which means most likely he has sub-midbass-midrange-tweeter. Really don't know why that was so hard to comprehend.
Op I'd just set it at the 1k and if they scream at you turn it down to a level you like.
Team B2
2008 scion xb bagged on 18's plastidipped matte black
4 18" b2 xc's pushed by 4 b2 m1s at .5 each
8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros.
157.7 sealed so far.
even for a midrange that still seems high but whatever.
  • Who's Online   0 Members, 0 Anonymous, 5250 Guests (See full list)
