I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly.
Not really abuse when your under powering them by 100 watts each ;)
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
It's not the 100 watts, it's that you aren't supposed to wire that ump under 1.5 ohms
its perfectly fine, i deal with JL on a daily basis. it is either user error or installer error
Do you know a way to put 600 watt RMS to each sub with my current amp?
i do....u could buy two 600rms amps....or an amp thats good for 1.2krms at 1ohm or 4 ohms....that'll get u the correct amount of power....
Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586
i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
6/18/82 - 4/17/12
R.I.P. to my sister Shana
lol it is that.. He said he abused his subs not amp there skippy
Exactly, he abused his subs with his amp set to 1 ohm. Read more carefully
I really didn't want to get rid of my 1200/1 :(
Fits perfectly in my amp rack
Like stated before, JL amps do the rated power from 1.5-4ohms, wire your subs to 4ohms and you will get 1200rms at 14.4v. So your voltage has to be stable.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Those amps do 1200 at 11-14.4 volts. They're constant power amplifiers.
  • Who's Online   0 Members, 0 Anonymous, 1686 Guests (See full list)
