18 in a trunk car?
how close is it to the trunk lid?
sub up port back probably isnt as loud as sealed forward in most applications.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
I don't see what's wrong with that, though people would say you can fit 2 15's instead of 1 18', but if it sounds good, then why not.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
2 15s is a no go they require 4.5 net each, cant do that.
also it would be at least 5-6 inches away from the port, or the width of the port from the trunk lid
This. You can also fit more cone area with multiple subs in the same space an 18 would use.
Edited by Toofast4u
cant seal an 18 forward, opening is too small
id rather not go through the hassle of selling it
im going to want 2 9512s then = too much fkn money
thats exactly the point i was making.
you asked why people are against it, i answered.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Sounds a bit radical, but you could do a cutout for the 18' on the rear deck, that's another idea, seen it done before on one of the build logs.
Yeah, with the 18' facing up in the trunk, you're gonna have one hell of a rattle.
2003 Kia Sorento
Team Subsonic Lows
most dont prefer the 18 in trunk box because of trunk rattle alone...if you can seal it forward would be best option....maybe you can slant the sub but most likely that wont work either unless your trunk is pretty tall...good luck
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
