PGG Posted May 22, 2012 Report Posted May 22, 2012 (edited) Well hello,this is my first post I have seen many videos about the Sundown SA-8 subwoofer which i found popular in here I came to ask...Is it worth buying for using it in my room? I want to have clean and LOOOOW bass Some other things now.. I already have a cheap Mac audio sub which is basically kind crap (Trying to sell it-no buyers for it ) I've also got 2 oval speakers for the vocals and a cheap car batt.The amp i use is this one: http://www.mac-audio...c94019fb2b11fdd (I always use the Logitech Z 2300 btw,main pc speakers ) I don't want to buy something that will not make any difference from what i already have..Can this sub handle the low's well?It's gonna get only a little power (around 160rms).Is it worth buying? I've also considered something else--->SA-8 or the speaker set of Edifier S730 ????????? Thanks for your time Edited May 22, 2012 by PGG Quote
john253a Posted May 22, 2012 Report Posted May 22, 2012 if you have the space yes sa8v2 in a t-line, or in a larger ported box around 28hz Quote
HunterJohnson Posted May 22, 2012 Report Posted May 22, 2012 T line for sure Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Bump4life Posted May 22, 2012 Report Posted May 22, 2012 home audio is a different animal. enclosure design is key. 160 is def enough. just study up on enclosure designs that work in large spaces. t line could work for you as well. make sure to have a LPF on it too Quote Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
HunterJohnson Posted May 23, 2012 Report Posted May 23, 2012 Also if u look at most theater boxes they are aeroported Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
PGG Posted May 23, 2012 Author Report Posted May 23, 2012 Thanks very much for your answers guys Quote
beaker Posted May 24, 2012 Report Posted May 24, 2012 You can slot port a HT box. The ones that are areo ported are usually tuned WAY higher With an 8 a T line would be awesome, it all depends on what you're going for with your design. Do you want it to POUND out some music? Do you want it to sound flat on music, but hit down to 20hz for movies? Do you want the best of both? A T line is the most efficent box, and is usually overlooked in car audio but works amazing in home audio because of the large box design. With an 8, it wouldnt even have to be that big. Quote
PGG Posted May 24, 2012 Author Report Posted May 24, 2012 I want it to play music,almost daily use Uhmm...Any sites that can help with the design of the box?I know how to make L-ported boxes but I've never before experimented with transmission line ones Quote
RooTxBeeR Posted May 24, 2012 Report Posted May 24, 2012 You can slot port a HT box. The ones that are areo ported are usually tuned WAY higher With an 8 a T line would be awesome, it all depends on what you're going for with your design. Do you want it to POUND out some music? Do you want it to sound flat on music, but hit down to 20hz for movies? Do you want the best of both? A T line is the most efficent box, and is usually overlooked in car audio but works amazing in home audio because of the large box design. With an 8, it wouldnt even have to be that big. 20hz for movies?! Shittttt, that's going below 10Hz! I know once I start to tackle doing some home theater setup, I am going to do a multiple sub set up. 2 boxes slot ported, same subs, same power. One tuned super low for 1Hz up to where ever the cross over will be for the next sub, which will go form that cross over to about 80Hz. Then a ported midbass driver from there up to around 350, then a mid from there to 3k, and a tweet from there to 20k. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
