hello guys and gals,
i read the fuse and wire sticky up top about 10 or so times and still alittle confussed. im running 0 gauge wire all the way back to a d3400 so i was going to stick a 250 up front and another 250 in the back towards the d3400, then go from the d3400 battery to the amp with a 100 amp fuse. does that sound correct?
running 2 hifionics brutus amps. 2400.1 @ 1 ohm. non strapped. so i'll have 2 power wires coming from the d3400 to the amps. fuse on each wire.
thanks for your time and answers.
joshua
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
You fuse to whatever the wire is rated for. Example would be if your 1/0 is rated or 300A ten don't use a fuse any higher than 300A. The fuse isn't so much to protect your equipment as it is to keep the wire from overheating and catching fire should it ever become shorted out on something.
so according to the fuse chart, for 0 gauge wire max fuse rating is 325 so would a 250 amp fuse up front and a 250 amp fuse out back before connection to the d3400 be alright? also, if im running 0 gauge to the amps would it be safe to run 100 amp fuses for each or would that be to small of a amp rating and they just pop like virgins cherry
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
yes, that is fine. i fuse my 1/0 at 250 myself but its mainly because i use CCA wire.
oh also, im going to be running a mechman 270a alt, what size fuse do you recommend for the big 3 power wire.
thanks and have a wonderful day.
joshua
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
sorry for so many questions but id rather be safe then sorry later.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
300 amp fuse for BIG 3, I run 300 amp ANL fuses on all my pure OFC 1/0 wire under 25 ft.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Thanks for the advice guys. I'll. Run a 300a for big 3 and 250a for the amp wires.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
Id actually run a 300 amp fuse up front and 300 in the rear. Only to keep as much flow as possible because you will probably lose some current over the wire run as well.
Edited by bassface
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
