I have two yellow tops that are about a year and a half old and they rest at 11.8 and 11.9 volts. I read that if they rest lower than 12.5 they are bad. They were on a mechman 250 alt with 2 runs of + and - with 1/0 and the big 3. My ? is there a way to bring up there resting voltage or do i need to buy new batterys??? Thankz
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
how accurate is your voltage meter?
Its about .02 off so i know its not that
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
Charge them on a battery charger?
So what's the resting voltage after a charge on a charger?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
I havent charged them with a chager yet . Going to buy one in the morning. I posted as soon as i read about them resting so low.
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
Charger would be step 1 :)
Batteries self discharge over time, so if they have been sitting for that long - expect them to be pretty dead. There might have been internal damage to the battery too because it was sitting in a discharged state for so long
They haven't been sitting at all !!!! They are in my blazer hooked up and I use it every day, but my amps are not hooked up.
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
Yep, this is not uncommon with Optimas now-a-days. The red top in my Mustang typically rests at between 11.8 and 11.9 VDC. I really can't comment why this is because I'd be guessing, but this is something that I run into often. Maybe one of the battery gurus here can chime in - Nate? Scottie?
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
