I was talking to a friend about running some 16 volt batterys off my singer ho alt. But he says that because they will charge to 18 volt it will kill my cars electrical? Is it true? And.if so how can.I get around that. Thanks
Yea some things might not work. Get a 14v bat and it'll charge at 16v and you should have less/no problems!
E34 540iT/6
yeah wont work charging that high shit gonna start frying...and only way i know of is to run a second alt that is separate from your cars electrical system..would have to be a dedicated alt strictly for you system and separate alt for your car
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
if your trying to get your car audio to 16 volt batterys id run them seperate jmo. Your pockets better be deep if your gonna change all your electrical over, i wont say it cant be done but imho it'd be dumb to do it to a daily driver, theres no use to do it
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
me and.my friend talked about that too. I see 12 volt batterys go to 14 volts and 16 volt batts go to 18. And.I.never see 14 volt batterys lanbled as 14 volts
Thought about this but no room for 2 alts.
Posted (edited)
What exactly does that do?
Edit: Lol ninjad
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I don't know much about it... And xs doesn't put any info on their website for some reason. But from what I know it steps the voltage down to 12v. You basically put everything but your amps on it (up to 50 amperes)
