Fosgatefeind Posted June 1, 2012 Author Report Share Posted June 1, 2012 So I run wire from my alt to this then my computer and then I run another wire from alt to batterys? Quote Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com Link to comment Share on other sites More sharing options...
wmrcs Posted June 1, 2012 Report Share Posted June 1, 2012 Yea some things might not work. Get a 14v bat and it'll charge at 16v and you should have less/no problems! me and.my friend talked about that too. I see 12 volt batterys go to 14 volts and 16 volt batts go to 18. And.I.never see 14 volt batterys lanbled as 14 volts http://www.sonicelectronix.com/item_38809_XS-Power-D1400.html Quote E34 540iT/6 Link to comment Share on other sites More sharing options...
Fosgatefeind Posted June 2, 2012 Author Report Share Posted June 2, 2012 Any one else help with this problem? I want to run 16 v daily but if it will be a problem I want a way to fix it help is appreciated Quote Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2012 Report Share Posted June 2, 2012 (edited) thats a step down module. useful for one alt cars that charge at like 16-18v. it "steps down" the voltage so that you can run all your normal car electronics off of it like the lights and ecu and heat and shit like that. all while using the regular unstepped voltage to run your stereo equipment. Edited June 2, 2012 by Kranny Quote Link to comment Share on other sites More sharing options...
Fosgatefeind Posted June 2, 2012 Author Report Share Posted June 2, 2012 So if I used this I would need 2 wires off my battery one to this and off of this to.my stock elec and the other off the batter to the rest of the stuff Quote Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2012 Report Share Posted June 2, 2012 i dont know exactly. i've never used one. i assume you have one 12v battery and the rest 16v. i would advise you to talk to some real company reps. not a "friend". this is some serious electrical work and if you fuck something up you can fuck everything up Quote Link to comment Share on other sites More sharing options...
deathcards Posted June 3, 2012 Report Share Posted June 3, 2012 if i remember correctly i think xs power has a bat or 2 with the step down module already in it Quote skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
MECHMAN Posted June 4, 2012 Report Share Posted June 4, 2012 14 volt batteries are the way to go. They need to be charged at 16.5 -16.8 volts, which typically will work with most vehicle's stock electrical. There is no efficient way to use "step up" transformers to run a dual voltage setup. If I were you, I would just run all D1400 batteries in the vehicle, and install our AVBM module to increase the charging voltage of the stinger alternator to the necessary 16.5 - 16.8 volts. 16 volt batteries need to be charged at 18.9 - 19.2 volts to be properly charged- that is way to high for your vehicle, and even most amps. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Fosgatefeind Posted June 4, 2012 Author Report Share Posted June 4, 2012 (edited) 14 volt batteries are the way to go. They need to be charged at 16.5 -16.8 volts, which typically will work with most vehicle's stock electrical. There is no efficient way to use "step up" transformers to run a dual voltage setup. If I were you, I would just run all D1400 batteries in the vehicle, and install our AVBM module to increase the charging voltage of the stinger alternator to the necessary 16.5 - 16.8 volts. 16 volt batteries need to be charged at 18.9 - 19.2 volts to be properly charged- that is way to high for your vehicle, and even most amps. Avbm module? Please explain Edit: nevermind I know what it is but will 16 volts kill my cars electrical too? Edited June 5, 2012 by FosgateFeind Quote Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com Link to comment Share on other sites More sharing options...
