Quick question. I have two RE MT 18"s that i am planning on putting in the trunk of a 98 catera. I MUST build two seperate boxes because i wont be able to fit one large box in all at once. So my main question is, what is tha absolute MINIMUM space for each woofer? I plan on porting both. My MAX box size for each woofer is going to be 4.5 cubes BEFOR port and sub diplcment. So will this be possible? thanks
EDIT: Ok so i did some google sketch up pics of exactly what the box should look like. The cut outs in the rear are fort the shock towers and the exaust hump.
The total net cubes is 12.3 with out the port. So now i need help on were to place the port. I want tunning at about 38Hz. The port MUST either go on the top, sides, or end of the box that faces the cabin, i can also fold down by back seats so thats why i was thinking about doing it there. Basicly with subs up what way will be the loudest?
Here is what the trunk looks like, again this is NOT a pic of my car.
Here IS a pic of my trunk with my current boc pulled out..The spaire tire location is were batts are going
Thanks for the help guys....O and BTW, as soon as this build is planned out, it will start so give some help, and receive some build pics lol
Edited by kbreudi
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
6.5 at a minium each after port and woofer displacment
I Don't know what the suggested box size is for the MT but even if what you have to work with is smaller it is still possible you just won't be getting as much as you can out of them. It will still sound pretty good though.
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
you can go down to about 4.5 cubes per sub after displacement, but to get the output you want your gonna have to UP the power to them.
I just want to make sure that with about 4 cubes each it will still get hella loud with 2200 rms each
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
any way you could afford more power?
Well i might... I was planning on two hifonics brutus 2607. Rated at 2600 rms, so i geussed about 2200. O and by the way i re did some measurements and i MIGHT be able to do one large 12 cube box.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
id listen to ray...step down to the 15s and u will probably be happier...imo 4.5cubes for an 18"mt that is only gettin 2200watts is to small
i likes me some audio stuff...
Well my main goal is to fit it all in the trunk of sedan, back seats still intact, almost stealth. I already have both 18's sitting in my room (well one is on the way with UPS). I redid some measureing i i can pull off a net of 12.5 cubes, one large box.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
Small Box - High Power
Large Box - Low Power
But I wouldn't do anything less than 5 cubes minimum or you're just defeating the purpose of having 18s.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
