Need help lowering tuning with proper port area.
I've been messing around on Torres and Bassbox Pro 6 but I cannot figure out the port frequency - port area.
It'd be helpful if someone could help.
Box is for 3 Rockford P2 10's on 1600w in a Kia Soul.
Trying to tune to 35 hz
Max dimensions are:
42 wide
17 height
13.5 long
Subs can face up or back
port up or back.
Not trying to get a design but wanted to give all info.
My problem is at 4.36 cubes Torres calls for 52 -70 sq inches of port. I can't get above 40 sq inches (9.7 per cube) without being tuned at 40 hz plus.
A couple of points to make:
You have 4.36 cuft gross space. After driver displacement, you have 4.1 cuft, and you still have to subtract port displacement.
Port area and box volume are not related.
If I have the right sub, the Xmax is 11mm? If that is correct, 40-45 sqin should be enough port area.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Did some refiguring and this helped out a lot
The following will just get you adequate net volume and port area, you can just mod it to your preferred aimings:
Enclosure Specifications:
Fb = 35 Hz
Vb = 3.539 ft^3
External Height = 17 in
External Width = 42 in
External Depth = 13.5 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 38 1/4 x 15 1/2
Back = 42 x 15 1/2
Left & Right Sides:
Side 1 = 12 x 15 1/2
Side 2 = 12 3/4 x 15 1/2
Top & Bottom = 42 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 9 x 15 1/2
Extension = 7 3/4 x 15 1/2
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
