xx1 Posted June 3, 2012 Report Posted June 3, 2012 I'm thinking about buying a pair of these : Soundstream Rubicon RUB1.2500 RMS Power Rating: 4 ohms: 1000 watts x 1 chan. 2 ohms: 1700 watts x 1 chan. 1 ohm: 2500 watts x 1 chan. [*]MOSFET power supply [*]Remote gain control included [*]Midnight blue finish w/ brushed accents [*]LED protection indicator will be illuminated when the amp has gone into a self preservation mode [*]Twin Stack Technology TM (strap amps together for double power) [*]Tri-Mode Capable [*]Three-Way Protection Circuitry (Thermal, Short, Impedance) [*]SMT built in cooling fan [*]Monoblock channel operation [*]Heavy duty aluminum alloy heatsink for extreme heat dissipation [*]Chrome-plated RCA level inputs [*]Chrome-plated screw terminals [*]Variable low-pass filter (50-150 Hz @ 12dB) [*]Subsonic Filter (10-40 Hz @ 12dB) [*]Bass Boost: 0-18 dB @ 45 Hz [*]Damping factor: >250 [*]Signal-to-noise ratio: 105 dB [*]THD (Total harmonic distortion): 0.5% [*]Frequency response: 15-150 Hz [*]Dimensions: 22-13/16"L x 8"W x 2-3/8"H [*]1 Year Autosoundswarehouse Warranty will that be too much???the BL's got flatwound coils and cooling. I'm planning on running the amps on 1ohm one amp to each sub. I just think they are at a great price and in case I want to upgrade my subs in the future I will have amps already. ***please help. this is my first "nice" system. Quote audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
xx1 Posted June 3, 2012 Author Report Posted June 3, 2012 or should I stay safe with the 1600rms @1ohm version ? Quote audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
Nate Futuristic Posted June 3, 2012 Report Posted June 3, 2012 id get the 2500s and set the gains accordingly in my eyes its better to have some head room Quote down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
bdog Posted June 3, 2012 Report Posted June 3, 2012 ya u should be good . BL's are good for up to 2000 and im guessing you prob wont get that out of the 2500's in the real world just be carefull with the gains Quote REP
Nikitaaa Posted June 3, 2012 Report Posted June 3, 2012 Always safer in the long run to get a bigger amp and turn it down then making a smaller work as hard as possible. You should be just fine with soundstream. Quote 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
KiKaZz74 Posted June 3, 2012 Report Posted June 3, 2012 You'll be fine. I have my bl running off a brz1700 and I can tell it is easily handling it. Just set gains properly Quote My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
loudNlow87 Posted June 3, 2012 Report Posted June 3, 2012 ya u should be good . BL's are good for up to 2000 and im guessing you prob wont get that out of the 2500's in the real world just be carefull with the gains It's a CEA Comp. amp. If he has the electrical system to supply it, why wouldn't he see it? Quote '11 Jeep Patriot New Build Head Unit: Pioneer AVH-P3200DVD Front: Massive CK69 Components Front Amp: Massive NX2 Rears: Infinity Kappa's Subs: 8 Sundown SA-8 v2's Sub Amp: AB 450.1 XS D3100 Come on 150!
xx1 Posted June 3, 2012 Author Report Posted June 3, 2012 all right 2500's will be! and yes I've heard those do rated power! Quote audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
bassface Posted June 3, 2012 Report Posted June 3, 2012 ya u should be good . BL's are good for up to 2000 and im guessing you prob wont get that out of the 2500's in the real world just be carefull with the gains It's a CEA Comp. amp. If he has the electrical system to supply it, why wouldn't he see it? The more power you put to a sub the more heat and resistance gets created. Quote
Guest Posted June 3, 2012 Report Posted June 3, 2012 as long as you have a high output alt from mechman or dc or something, with a battery or two, then you should be good Quote
