Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
ok so you dont have woofer in the lower part of door. well my opinion still stands. dast facing at the glass or right noext to the woofer. you can prolly fit it in stock location with stock woofer cant you? or is stock size a 5x7? or 6x9?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Since you got the 3sixty, You should have no problem setting it up right.
I've been told not to put it too far down the door if I couldn't time align it with a processor, and up higher would be better. But you should be all set with a little tuning.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
With the 360.3 you can time delay everything to make it sound perfect. Might take a few hours to figure it out, but with the right settings you don't have to worry about if the tweeters are closer or farther away than the mids.
True that. Didn't even consider the time alignment from the 360. Makes it easy, I can basically put the speakers anywhere I want to.
They both wont fit. Heres the plate. http://www.sonicelectronix.com/item_4966_Scosche-SA68.html
Yeah, thats why I want everything high on the door. The stage sounds real low with the mid down on the door panel.
SMD Super Seller
My Feedback Thread
The deck carpet cleans it up a bit. Need to figure something out for the square openings, though, I have a couple ideas.
fiberglass in some volt meters. like the vm-1 1 wired to the battery bank 1 to the sub amp.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What battery bank? Its a low power setup. I like the idea though.
ok, a vm-1 in 1 hole and a wm-1 in the other lol. or at least we are all guessing its a watt meter.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
That's what I was thinking, But to look back at the voltage sucks!! LOL. Also would look nice to have a smoked peice of plexi, either with a vynil sticker or etched with some led's hitting it. Would look sick.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
yeah 2 small plexi pieces with a logo etched in with back lighting.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
ok well if it were me id try to find a clean place to put the tweets on dash. if no spot, then put it near the 6.5. yea you could tune it with the 360 RF but why not just make it so you have to do as little tuning as possible.
BMW M340 xDrive
No spot on the dash. I have the pillars, but they will face away from the listeners, just by a few degrees.
SMD Super Seller
My Feedback Thread
