If I build an enclosure and use plexiglass on the back, is it going to affect the sound?
Also with the proper bracing could you mount the subs on the plexiglass?
1998 Ford Contour
Head Unit: Pioneer DEH-P8400BH
Front/Rear Door Speakers: Alpine SPR-68 (Type-R 6x8)
Door Speaker Amplifer: Kicker ZX650.4
Subwoofers: 1 SSA Icon 12"
Amplifier: MB.Quart 1.1500d
Second Battery: XS Power D925
Well I think I'm going to plexi the top of the box so you can see down and look at the motor. maybe add some led lights as well.
1998 Ford Contour
i always wondered about this... ive seen it done but i still feel like plexiglass is a risk lol
if glass is apart of the word i dont trust it lasting long....
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
I wanted to do this before but its very expensive! The thin stuff is cheap but check the prices for 3/4 or 1the inch lol. Scratched that plan off my list fast ha ha.
I have also wondered if i could some how glue sevral layers of thin to get the thickness i need. But wasent to sure what would work for the glue and stay perfectly clear. Anyone?
What I've done in the past was lay a bead of clear silicone along the edge and put C clamps all the way around. I've also 'torched all sides of the layers together and it worked pretty nicely as well. Just make sure that there is no air pockets between the layers, otherwise it's junked. Lol
2001 Toyota Corolla CE:
4x Crescendo PWX6.5's
2x Crescendo FT1-SE's
1x DC Audio lvl 2 M1 8 (looking for more)
Slot port box 0.7ft^3 @ 31.77hz
Rockford Fosgate R750.1
1/0 Knu wiring all around
Looking for XS Power D1200
Thickness vs thickness plexiglass is stronger
think about fishtanks, 250gallons of water 200lbs 8feet 2feet by 2 feet, think wood that was 3/4 (or a little less) it wouldnt be able to hold the water even it it was resin'ed to waterproof it...
I thing it might effect sound couldn't tell ya, my 1" thick plexi side on my box is one of tne stronger points on my box, needed no bracing and its the biggest peice 24x 40.5
where the wood top and bottom needed bracing and they are 18" x 40.5 now braced with a 2x4
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Where did you purchase your sheet of plexiglass?
1998 Ford Contour
  • Who's Online   0 Members, 0 Anonymous, 908 Guests (See full list)
