BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
I know what setup gets loud in my vehicle the 4th was to try out a bandpass. with the new setup im 100% sure its going to get NASTY. and I agree the 12s are much better imo as they will have alot more motor force, more excusion per woofer, and rated to take big power. and daily and spl ports will be easy to swap
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
So what will u be Doing with the 8s?? Can't wait to see what u do next.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Not sure might keep them for one of my other vehicles. And ill start building the next box next weekend. so stay tuned for pics
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Seemed like you had better luck with aero's, we will see once you start building the new box, let us know about the design before you start building :D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
From personal experience I would build two different boxes for spl and daily. Swapping ports is never going to achive the same results as building an optimum enclosure for whatever you choose to run. For example spl boxes have a smaller internal airspace than a daily box 99% of the time and just swapping ports doesn't give the same effect as building the enclosure that is ideal for your subs. Also with building seperate boxes you are able to tweek the shape and every other variable of the enclosure to achieve maximum spl. Trust me when I say that shape of an enclosure plays a big part in how well it will produce spl wise. The location of the woofers on the baffle, how much space between the back of the magnet and the rear wall of the enclosure, and how far away from the port the woofers are will all be factors of overall output as well.
I've been running Sundown products since 2008 and have a ton of experience with low power to over-powered setups. If you need any tips to gain spl all you have to do is ask.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
any inputs on the octaports? A friend was telling me about them but I havent ever seen or heard how they perform
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Octoports are for ppl trying to get a big aero ports but not able to kerf wood into a circle, or feel like wasting sheets of wood just to stack rings to make ports. I'm sure they work good, but I would rather spend the time and stack rings to make a port.
stacking enough rings and making a good flare would be heavy as hell and take a month to get sanded down right
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
From my understanding octoports are mostly just for cosmetics and don't have any pros over regular aeroports performance wise.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
