BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
Octoports are for ppl trying to get a big aero ports but not able to kerf wood into a circle, or feel like wasting sheets of wood just to stack rings to make ports. I'm sure they work good, but I would rather spend the time and stack rings to make a port.
I dunno man I think they look damn good...
Audiofanaticz work.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
they do look much better than an aero for sure and idk where to get an 8" aero port from im not flaring it myself i want it to look like a precision port
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
Get an 8 inch concrete former tube from home depot, glue wood around the end of it and hit it with a huge roundover bit?
I have 15ft of 8" pvc but i dont feel like a round over is near as good as having a huge flare like the precision port
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
http://www.caraudioc...ilt-custom.html
thanks for the suggestion but i do not want metal flares i would be scared of it resonating for one and 2 i dont have anyway of cutting it to size.
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Copied from his description. The red part, and he will cut it to any size that you want before it is shipped to you or you can probably use a hack saw to cut it.
the ports are made from the metal of your choice. they are paintable and very strong !
all seams are spot welded and can be sealed with either silicone or something of your choice either by you or me
all seams are made with a flange to be tight and smooth on the inside (airflow side of the port)
these will give you an increase over a traditional slot port and are not as permanent they can be adjusted !
they are not going to ring and have been tested to not ring it was a question in a few of the early prototypes if you are still concerned i can apply deadener to them just like your door or roof
ok but like everyone says when going for numbers a first box is never your last right? so if i cut they port to size and then need it longer for a second box if im not happy with the first its not like pvc flares where i have access to over 1000 feet of 8" for free
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
