BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
strengthen it with fiberglass if need be.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
well than can you explain what the comparison difference of a single 15 sa vs z v.3 and 2 12 sa vs 2 12 z v.3 because your not making any valid point other than you prefer the sa model if everyone could get louder with sa why would they make bigger lines? the z vs sa is not a match 19mm xmax on the sa doesnt come close to the z v.3 and the z has alot more motor force. the test i posted above is valid proof the z can be louder than the sa.
So then with this said why not just go with a pair of Nightshade 12's then? They are no doubt going to have the potential to be much louder than the Z's, not to mention that you have the power to make them do so.
I think with your application that 2 high end woofers are going to be louder than 2 middle of the road ones, but if you were going to be running more subs and the same amount of power then going with the middle of the road sub is going to be the better choice for higher spl.
So it's settled then, Nightshades for you ;)
the nightshade is not going to have much more potential than the Z's. At the max/high end they nightshades have .5db gain thats it.
Whatever you need to tell yourself to justify buying the Z's instead of the Nightshades. I'm sure you've never ran a pair of Nightshades so spouting off at the mouth looking like an uneducated fanboy is the last thing you need to do to try and make your point.
Now as for me I've personally ran the Nightshades from the first run of the woofer to the V2. I've also done real world testing for Jake in my vehicle in a direct swap situation and know what the difference is between the two. In a direct swap from 2 NS V2 to the Z V3 the Nightshade was 1.6 db louder off a pair of 3500d's. Pretty far away from the .5 db that your boasting. That power is very similar to the power that she is going to be here so I don't want to hear a damn thing about not enough power this or that.
I honestly get sick of know it all forum trolls trying to argue with real life facts. I'm not the type of person to throw random bullshit out there without anything else to back it up. So before you reply to this post take a minute to see what I've said and hit the delete key on whatever you were going to type because I honestly don't need to hear anything you have to comment on this any further.
From what ive been told the z v.3 is a better woofer all around than the ns v.1 and v.2 now the ns v.3 should be a different story but they wont be coming in 12s
Again, I don't know what you've heard but each situation is vehicle and enclosure specific. I guarantee you that a pair of NS V2's will be at least a db louder with the right box over a pair of Zv3's. I've done the testing to justify the claim. I did watch the video that you put up with the sa swap to the Z swap and like you said if everyone could get super loud off of the sa why would they make the higher end lines. Well, that is the case with the Nightshade as well. With a properly broken in Nightshade or even one with a softer suspension the power that you have is more than sufficient and only about a thousand watts less than what I ran in my car for 2 years.
Like I told you before I'm a personal friend of Jake's and have done testing and qc for him on some of his products. My car has been used as a guinee pig for quite a few of his creations and I wouldn't make a suggestion to you if I didn't fully think that was the right thing to do. But some people gotta learn on their own, however I'm glad I listened to the vets in the sport that helped me out when I first got serious about competition. It has helped me to the 2 NSPL titles that I've won and probably wouldn't be there had I not followed their examples ;)
the nightshade does have a higher potential, but its all relative. it will only be louder, maybe, if you put more power to it. other wise it wont be able to reach its optimum excursion for output. so the reason to upgrade is to run more power.
While your partially right refer to the post above where I stated a direct swap test between the two subs.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
Back to my build everyone, I got the box built today. Came out great
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Smartasses will be smartasses, plus there's a lot of factors Nightshade didn't mention anyways.
You're making extremely great progress, have nice equipment to match, you definitely know what you're doing when it comes to install, and it's always good to have a female touch to the male dominated world of bassheads. I'm definitely tuned in for this build.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Thanks for the compiments, I really appreciate it not many pretty girls like a quarter pound of sawdust in there hair every day and like to give them selves mini hair tricks haha :D
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
I'm looking forward to seeing the round over on that port. Hurry up!
Its been rounded over lol Just keeping you guys staying tuned to my build, since im not SOTM worthy haha ill port pics
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
What do you think about the quick disconnect?
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
