BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
yall are wrong with the angle, yea its 45 degrees but each board has 2 sided, so one side get a 22.5 degree cut and so does the other. So you need 22.5 degrees not 45, that would just make a square
Looks great! How did u find all the angles for that port!? I seriously suck at angles
The angle of cut is 67.50 each. The easiest way to derive this is drafting software such as autocad or the following formula: (n-2)X1800 where n is the number of sides you want. Example for 8 sides we have (8-2) X 180 = 10800 . Now we are dealing with 8 sides so 1080/8 = 1350 . To get the angle of cut we divide 135/2 = 67.50
Another example for 6 sides we have (6-2)X180 = 7200 and 720/6 = 1200. Therefor the angle of each cut is 120/2 = 600. Hope this helps you all....
And so are you too, 22.50 will not give any regular (symmetrical) figure.
Oh really? Go back to school kid.Each cut on each piece of the octagon is 22.5
SMD Super Seller
My Feedback Thread
:search:
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
you have just exposed your lack of any formal education.....
pretty sure 16 x 22.5 is 360 man...
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Have I now? You are measuring from the horizontal plane. A saw blade is vertical, 90deg from the horizontal. Tilt that blade 22.5 deg from vertical to cut the angles to form the octagon.
SMD Super Seller
My Feedback Thread
