SAZ-3500, what dose it do RMS ? @ 2 ohm's - @ .5 ohm's
jeez, first underlining a whole response, now 1" font.
get the alt then see if the subs keep smelling. for now, keep the volume down
Edited by Kranny
Get your electrical straight. Till them turn down the gain by a lot
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
I dunno,... i maybe on the early beer buzz,... it is friday... but
Your burning coil on low stock alty power?... correct?
Hell, you get a high output alty, and that amp will actually show you what it can do.... you think you smell coil now?? with no power?.... thats probably saving the subs from going up in smoke for good......... set your gains,...... properly..... or, maybe your expecting to much..????
I guess, what i read was, "i smell coil" and the answer is he needs more electrical????????...... i have to be mis-reading???
EDIT- please be gentle,... booze is on.........
Or, i dont understand the issue in full...
Edited by KyLar96
when the amp is tuned with the dd1, voltage is probably sitting at 14's. with the subs hooked up, voltage is dropping. thus clipping is induced earlier. which would explain the coil smell.
doesn't tuning with car off help tune at 12 volts?
might be dumb but when i tune my amps i leave car off so when i do play them and get voltage drop i wont get clipping
edit: OP are you sure the smell is coming from the subs? i have seen where some people think its the subs then later find out it was the tweeters burning on some 6x9
Edited by Miguels
Thought you were an american bass rep. Why you running sundown
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 591 Guests (See full list)
