So I burnt a leadwire and the guys at psi told me to make sure volts are staying high enough. They aren't. They sit at 11.2 to 12.2 while bumping hard. I want to sell my car in a few monts but want to bump till then. I have 2 yellow tops. Could I add a xs in trunk also or is the only way is to get a bigger alt?
What amps are you running?
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Posted (edited)
Car make and model? What size alt? What is your current electrical setup? And as HHR said, what amps?
Edited by FeArZ
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
nathan said not to run XS with other brands, in reality it shouldn't be done anyway. But we need to know what amps, ohm load, vehicle alt specs, etc, before telling you anything.
And just as a general tip. here are several ways to keep your voltage maintained as high as possible.
1. Upgrade size of wire on strength of connections from Alternator to Battery and Frame ground. As well as from the battery to the Audio components. This is sometimes called the "Big 3"
2. Reduce the length of all power wire and grounds to the amplifiers, sometimes people leave extra wire tucked under carpets because they think they may need it someday. This reduces the current capacity of the wire. Cut it to length.
3. Properly tune your amplifiers. Gains turned up too much not only add distortion, but they cause the amps to draw more current and run less efficient.
4. Keep your batteries charged. Batteries can be depleted over time. For the last 10 minutes of a car ride, it may be wise to turn down/off your stereo to let the alternator top off the batteries. Or plug in a charger in your driveway/garage.
Ed Lester
ShowtimeSPL Host
My old Build Log
Actually Nathan said running XS with other brands is not preferred but is possible.
You DO NOT want to run XS or any AGM batteries with a battery of a different type or chemistry. Example, a wet cell die hard will not mix with a XS agm type.
It is not ideal but Optima and XS batts can be compatible.
Ed Lester
ShowtimeSPL Host
My old Build Log
Can't help you out Sir without the information we need to acess your situation ...
Ok so right now this is my set up. Jl 1000/1 mono with psi 1200 rms 15. Pioneer avh 4300 dvd. The stock alt is 80 amps and I have 0 gauge from front yellow top to one in rear. Then 0 gauge to cap and then 4 to amp. Haven't done big 3 yet but could it make a big difference. I'm looking at a hifonics brutus amp after my sub is rebuilt.
he told me that even other brands of AGM batteries can cause the over all lifetime of the xs battery to wear down due to different resting voltage...
sorry had to post that lol
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
