Only thing I see that I don't like is the 1.47v vcore but if that's the mobo overclocking it for you then it did it's job and got you the highest overclock it could.
Have fun wiring up them GPUs! Make sure you run it through Heaven or 3DMark and post results!
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
HUH? I manually entered some quick OC settings..... I entered in 1.465 (with heavy LLC which = 1.47 under load) set VCCIO, SA, etc... voltages and rebooted... and to my surprise it posted.. 5ghz across 6 cores and only using 1.47v, is a damn good chip, even if it isnt stable.... see what im saying? Sandy Bridge E is an amazing platform. Ive spent the last 20hours or so playing and setting things up, and the rapid response from the OS is nice and crisp (of course that has a lot to do with the SSD) I ran Stress prime95 64bit version on "blend" for that last 5-6hours while streaming youtube, and downloading updates.... No slow down what so ever. This was all done at the stock speeds ( :( ) but like I said before, this isnt my PC and can only do what the owner wants! Highest temp in a 74f ambient room was 58c under 100% load. Pretty damn good HSF combo i must say.
All in all, this was a very fun build, and cant wait for the gpus to get here
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Oh, just to let you know, many games and programs actually perform better with HT disabled. Test test test test! :(
You do realize the Pentium4 days are over right?
Yes.
These CPU's are hyper threaded, you know?
Hammerdown... 1%
Yes.
He wasn't saying HT doesn't exist anymore.
Leaving HT on newer processors is much more beneficial than it used to be.
Keep it enabled.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
Yes.
Keep it enabled.
Newls1 is a member at another forum I also frequent.. HT works for some things yes, but you need to test if it is beneficial for the program you are intending to use it with still.
Hammerdown... 1%
Yes.
Keep it enabled.
Are there any video editing or rendering softwares you know of that perform better with HT disabled?
wtf is lolcats?
Yes.
Keep it enabled.
Archicad/Lightworks: http://www.archicadwiki.com/Multiprocessing
Depends if you are using CPU accelerated or GPU accelerated rendering mostly though. Legacy X87 instructions are the major culprit in either case.
When using CPU only then HT helps for the most part due to lesser amounts of X87 that are used. If a GPU is being used then the windows threading management engine basically falls flat on its face. This is why many games accrue such poor performance increases even when programmed to make use of 3+ threads for quadcore CPU's for example.
I'm confused here, whats bad about saying to test your target program for performance benefits with certain hardware configurations?
Hammerdown... 1%
Yes.
Keep it enabled.
Archicad/Lightworks: http://www.archicadw...Multiprocessing
I just don't think it'll make much of a difference at all in a build like this. 6C/12T and 3 670's will RIP through rendering. I doubt you'd ever see much of any change enabling or disabling HyperThreading. It'll cut down on heat, it'll allow more applications to run concurrently. The i7's HT is far more efficient than the P4's. For the investment of testing both options I sincerely think it'd just be a waste of time.
wtf is lolcats?
Awesome looking machine Sir ...
