Dremel or Router?
He never said anything before your response about them being good or not being good for boxbuilding.
That's exactly my point... Maybe you should READ my post again.
Either way, you are wrong, and a dremel has its place in car audio fab, and even box building....
I would never suggest a use of a dremel for cutting speaker holes, or rounding over corners because a dremel cant compare to a routers power, but there are many uses for them in box building at times (not always) and examples given...
Not bashing you, dremels do have there spot. I would suggest to try and not use them though when fabbing anything wood related, I used one yesterday to flatten some edges on a amp rack I built, was very unfriendly and not fun to use. I am sure if I had a router, would have have soooo much better and cleaner in the end.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I've built so many boxes I can't even count and have never used a dremel on them
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • 1 month later...
Router Vs dremel... .. Dremel not even close to buidling boxes.. I think the thread should be Jigsaw vs router... Yeah..
  • 2 months later...
I still need a router, I cut all my wood circles for the stuff I fiberglassed with a jigsaw, cause I dont have a router yet, dremels are great for removing fiberglass and shaping it around corners after it dried, so they both have there place, you can get by without a router and using a jigsaw, but a router will give you perfect circles and save alot of time, its one of the next tools im gonna be getting :D, a table saw would be nice too, but a circular saw and a straight edge works, just takes more time, and you have to do a lot more measuring :P its all about time and what you need, a dremel from my exerience does not have the power to cut through 1/2 to 3/4 inch + mdf, it reall struggles, where a jigsaw would just cut through it no problem, even with a dull blade :P
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   1 Member, 0 Anonymous, 308 Guests (See full list)
