Pretty good idea. You should just be able to use threaded inserts and some bolts. Of course with weather stripping or something in between.
Any more input? Look like a doable design?
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
Looks like it .........but wont it be hard to remove/install because it will rub against the top and bottom of box and that joint at the 90* would take alot of stress twisting it in.
What about PVC or Aero's....make removable and have 2 different lengths.
Or 2 ports one on each side that are square tubes made of MDF...they dont go all the way to top/bottom of box but are 4 sided and removable. You could hav e ashort one 4 spl and longer ones for daily.
Edited by Chris Hammer
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Could I make a box that has a port on each side 1 for daily and the other for comps? Just have a sealer block to cover port not in use?
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
That port design to me wouldnt work well. First of all the inner part of that port isnt going to be screwed down at all and braced so it will move in the box under pressure. Second for only one part on the front of the box bracing the port it will not hold that much pressure of the box being pressurized of the subs moving and will break it off. You need a port that is not any bigger than the wall of the box you install it on. Just like what Meade has in his tahoe. You want to have it so that the port is like suspended inside the box. I.E. not touching any of the other walls.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
i wouldn't advise doing a removable slot port. it'll be hard to seal correctly, and it won't be attached properly. i'd prefer doing a square/rectangle removable port
Thank you Torres, i was trying to think of the name of that port style but you knew it lol.
I think I could do the square/rectangle port
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
