CrazyCricket12 Posted June 13, 2012 Report Posted June 13, 2012 Planning to add a crescendo c1100.4 when I start my build and wanting to run some rockfod pps 6.5s. My questions is should I get the 4 or 8 ohm versions? They are 100 watts rms and the c1100.4 does 180 watts at 4 ohms. I know I don't need to over power the mids but would I get enough power at 8 ohms? Quote
CrazyCricket12 Posted June 13, 2012 Author Report Posted June 13, 2012 Link to speakers http://www.sonicelectronix.com/item_43387_Rockford-Fosgate-PPS8-6.html Link to amp http://www.crescendoaudio.com/index.php/products/amplifiers/item/concerto-c11004.html?category_id=2 In case you want all the specs. Quote
EdgarG0721 Posted June 13, 2012 Report Posted June 13, 2012 How many are u getting u could run them bridged all under the same load Quote
CrazyCricket12 Posted June 13, 2012 Author Report Posted June 13, 2012 I was only planning on getting 4. 1 for each door. Quote
EdgarG0721 Posted June 13, 2012 Report Posted June 13, 2012 I would run 2 4 ohms on 1 channel and another 2 in another to give u 2 ohms at the amp and use th other channels when u get some tweets Quote
CrazyCricket12 Posted June 13, 2012 Author Report Posted June 13, 2012 Would that not b to much power on them? Quote
Ddub847 Posted June 13, 2012 Report Posted June 13, 2012 y not run 2 8 ohm on 2 channels that leaves you 2 open channels for other speakers... Quote
IBleedMusick Posted June 13, 2012 Report Posted June 13, 2012 I agree with Ddub and considering I have no experience with the RF's I would stick to RMS I am not sure they will handle 50w over RMS so get 4 8ohms and run 2 to 1 channel and 2 to another channel which would give you a 4 ohm load at the amp and leaves two open channels for tweets. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
CrazyCricket12 Posted June 13, 2012 Author Report Posted June 13, 2012 Ok thanks. What tweeters would you guys reccomend? Quote
IBleedMusick Posted June 13, 2012 Report Posted June 13, 2012 Ok thanks. What tweeters would you guys reccomend? Match gear and get the RF super tweets. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
