wassup guys was installing my ns1 tonight and when i went to put in the first ground wire it sparks blue any ideas everything els is in the 3 powers rcas not sub wires tho. system was running fine earlier with my 3000d and when i went to swap in the ns1 it sparks, thanks for any help.
Always disconnect your battery when installing an amp.
Head unit: Pioneer P880prsFront stage: Alpine Type X 17PRO componentsComponent amp: PPI BK 800.4Subs: Two SSA XCON 12's in 4.5 cubes tuned to 34hzSub amp: PPI BK1300.1Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
Team SSA
Team Alerion
Posted (edited)
Even when you hook up the disconnected battery you are going to get a spark like that when you go to hook the battery back up at the battery terminal .
The capacitors in the amp discharge slowly when the amp is not hooked up. All you were seeing was a spark from the current draw to recharge them. It scares the hell out of you the first couple times you have to deal with it but its usually nothing to worry about. Accidentally hook an amp up backwards though and prepare for an even bigger spark followed by smoke usually...
Edited by kandiman71874
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
^^just what he said. My dc 5k sparks really bad when i put the fuse in the anl fuse holder and i always expect it but it still makes you jump because of how loud and bright it is. Just look over every connection on that wire to make sure no strands are loose or about to ground out before you pop that fuse in and you will be all good.
Normal, and the only time I disconnect the battery is NEVER. Why? Because it is a waste of time, just be smart and realize what you are doing, simple.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 734 Guests (See full list)
