Is my current port too small?
hey all,
so i currently have a ~3 cubic foot box for my 2 12" Type R's.
with that box i have a make shift 4" aeroport tuned to ~35Hz.
playing full tilt i sometimes here port noise.
should i add a second or even third aeroport?
and if i do add X amount of aeroports, will this make my system louder?
Adding ports will do a number of things. Without adjusting length, you will be completely changing the tuning frequency and response of the setup. If you do add an aero and adjust the length of each to keep approx. the same tuning, you will see a slightly more output at your peak freq. and a steeper roll off below it.
-Drew
detail.gifI am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. detail.gif
uhoh_45 said:
dont be a pussy P give the jeep to drew
-Drew
yes, i did realize i did have to adjust legnth. which in my case would be problematic as if i had 2 4" aeroports, for 35Hz i would need them to be 16.5" long, but my box is only 16" in depth. i guess i am stuck with my port noise, seeing as how i dont want to go above 35Hz.
you could put bends in the ports or have them exteded out of the box. Or 1 6" flare port 15" long with a bend
ahh! i see, very interesting.
i didn't even think an aeroport could be designed with bends like that.
that would much more helpful.
thank you very much for the pics, didnt understand the concept without it.
but will also consider what noob said about losing output at far off frequencies.
  • Who's Online   0 Members, 0 Anonymous, 1350 Guests (See full list)
