I need a box diagram for 1 12" Rockford T2
Hi I'm planning on building my own box for a ROCKFORD FOSGATE T2. I was wondering if someone could help me with a diagram with the dimensions, because I'm not sure how to incorporate a port into the box and where to put it for the best sound. I wanted it ported and it has to be small enough to fit in a sedans trunk. Any help would be much appreciated. Thanks
If you want to save room in your trunk, focus on width, and height more than length. The T2 likes 1.75 - 2.25 cu ft after displacement for ported.
Here's a helpful forum topic on how to use torres calculator, and how to make a design on google sketchup
http://www.stevemeadedesigns.com/board/topic/145174-ported-box-design-a-tutorial/
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
This should help, though I've heard the port should be on the driver side facing the same direction as the sub in a sedan, that's how I have on mine.
Here's to help explain a little better on ported boxes, but for slot port, the port should between 12 - 16 in^2 port area per foot
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator/
2003 Kia Sorento
Team Subsonic Lows
Here is a suggestion, should fit in most trunk type of vehicles:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 2.5 ft^3
External Height = 14 in
External Width = 29 in
External Depth = 18 in
Port Width = 2 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 29 x 14
Left & Right Sides = 15 3/4 x 12 1/2
Top & Bottom = 29 x 15 3/4
L Port Internal Assembly Parts:
Front to Back = 13 1/4 x 12 1/2
Extension = 4 1/2 x 12 1/2
Assembly guide (generic dimensions):
PM questions if any as I usually don't check this section.
  • Who's Online   0 Members, 0 Anonymous, 1466 Guests (See full list)
