DC Sound Lab
Copy of email sent to me On Jun 12, 2012 1:48 PM, <[email protected]> wrote: Only thing is that Lv6 is only a 18, the 15" frame does not hve a 9" spider landing, that is what we need to build it in a 15. The Lv5 we will be able to build into a 15 and will have a 3.5" coil
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
I just hope the m2 lvl 6 softparts can keep up with the thermal/coil handling. Kinda bullshit how the m1 lvl 6 was built, half-ass.
from what chode says there keeping up so far and I know for a fact he's going to try his best to find the flaws and that information will b relayed to rusty so it can b adressed before they r released for sale Edited by gotdrop?
2x dcaudio lvl4xl 15's
1x dc power 270xp alt
2x rockford 2500 1bd
2x big3 2x front to back 0.gage jl
1x optima yellow top under the hood
1x xs power d3100
2x xs power 925
148.6 db sealed to music 149.5 db sealed 42hz term lab
Not a necessary comment.
The level 6 was never meant to be built as a 12, but you wanted one so it was built with you knowing that it could fail. Shit tends to break when you put 7500w to one sub that was never meant to be built as a 12.
The m2 level 6 was only going to be available as an 18" as I yesterday. I did however manage to peak rustys curiousity and he is going to try and build it as a 15" as well. No promises on the 15", but it is going to be tested to see if it can be done with the standard 12 spoke basket.
The level 5s will be available as 12, 15, and 18s. 10s could be a possibility, but they will be more expensive than the 12s due to needing a mounting ring because the motor is bigger than the mounting hole.
:+1:
Edited by srool
Old level 6 was beast I've seen a few in action and they got loud.. but like myself I use to try and get 2 subs to sound like 4 and id dump tons of power into them..so I was able to find mechanical and power limits..I had a buddy with 2 9ks on 2 lvl6 15s..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
well to clear some of this up. there was No issues with the m1 lvl 6 soft parts. The m1 lvl 6 was only an 18" version by production for a reason. when you ask for something outside this there is risks. For example a 4"coil 12" subs with 10" spiders have limitations. So the end user must exept that. The issue on that small of woofer is the spider allows more travel then the surround. So if you blow out a surround its user error not product failure
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
