Just run a positive 1/0 wire between the two battery's positive terminals and fuse both ends of the wire close to the batterys. And if you have enough wire, run another 1/0 wire from the neg terminals on each battery. So like this:
Batt pos -----fuse-----------------fuse-----batt pos
Batt neg --------------------------------------batt neg
If you dont have enough wire for the neg run, then just ground both batterys with 1/0 to the chassis or frame.
Edited by sprkn_ranger
1. Make sure you have an alt that can power both
2. + from front batt to back batt
3. - from front batt to back batt
4. - from back batt to a good ground
Oh ya forget to say fuse the positive on both ends. At least one end
Edited by graham0599
Never seen an alt not be able to power some batts? Care to elaborate on this?
I have had 6 batts on a 60 amp stock alt worked just fine just takes longer to charge them
Searching helps a lot. It's soooo easy to do, and you could even search on google. I doubt anyone is going to spoon feed for such an easy subject since there are plenty of write-ups and how-to's of adding another battery properly as well as upgrading your alternator (which you should plan on doing if you plan on pushing a lot of power)
Fusing just one end is totally pointless, if you have a positive wire in between two batteries, and only fuse one end and the wire shorts somewhere, the un-fused battery will burn up the wire and probobly burn your car to the ground. You MUST fuse both ends to protect the wire from overloading in case of a short.
this guys, is a genius.
helps any/everyone and is usually right.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
