How do i add another battery?
Just run a positive 1/0 wire between the two battery's positive terminals and fuse both ends of the wire close to the batterys. And if you have enough wire, run another 1/0 wire from the neg terminals on each battery. So like this:
Batt pos -----fuse-----------------fuse-----batt pos
Batt neg --------------------------------------batt neg
If you dont have enough wire for the neg run, then just ground both batterys with 1/0 to the chassis or frame.
Edited by sprkn_ranger
1. Make sure you have an alt that can power both
2. + from front batt to back batt
3. - from front batt to back batt
4. - from back batt to a good ground
Oh ya forget to say fuse the positive on both ends. At least one end
Edited by graham0599
Searching helps a lot. It's soooo easy to do, and you could even search on google. I doubt anyone is going to spoon feed for such an easy subject since there are plenty of write-ups and how-to's of adding another battery properly as well as upgrading your alternator (which you should plan on doing if you plan on pushing a lot of power)
Fusing just one end is totally pointless, if you have a positive wire in between two batteries, and only fuse one end and the wire shorts somewhere, the un-fused battery will burn up the wire and probobly burn your car to the ground. You MUST fuse both ends to protect the wire from overloading in case of a short.
this guys, is a genius.
helps any/everyone and is usually right.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
  • Who's Online   1 Member, 0 Anonymous, 1486 Guests (See full list)
