Right now I'm only running a Rockford Punch 400.4 and a Kicker ZX750.1 and I want some more bass. Nothing too crazy, but more than enough to have some fun with.
I'm going to be ordering two FI Q 12s, fully loaded and a Hifonics ZRX3000.1D to power them. I am currently running stock electrical with a optimia yellow top and a 1 ferad cap that I got for free and use for the voltage meter on it. Should I upgrade my alt and go from my current 2gauge wiring to 0/1?
Before I order the subs should I get them in dual 1 ohm or dual 2 ohm? Going to be running the amp at 1ohm of course.
Edited by osage
http://i1356.photobucket.com/albums/q722/Joey_Medders/8c5ab882-507f-4d37-9a86-1c34d3ccec2e_zps1dd7c0f1.jpg
2007 Yamaha FZ1 - Full Yoshi system, Airbox mod, BCM filter, PCIII, PCIII quick shifter - [email protected]
2005 Hyundai Tiburon GT - I/H/E Crower Cam, NGM reflash - [email protected] (slow as hell) - audio car (142db) - RIP December 31st 2012
Pioneer AVH-P34000BH
Hifonics ZRX3000.1D
2 Fi BL 15s - dual 1ohm - cooling, flatwind coil, daily
9 cube ported @34hz
Hifonics ZRX1000.4
RE Audio XXX6.5C front doorPyle PLG69.4 rear panels
KnuKoncepts KCA 0/1 big 3 & 2 runs to back
KnuKoncepts RCA/speaker wire/distro
XS Power D3100 under hood
Dual 1 ohm and yes you will need to upgrade your wiring to 0 AWG and your electrical. That amp is not CEA certified so you may not see the full 3k.
EDIT: FIXED SORRY.
Edited by Joe X
http://www.sonicelectronix.com/item_23550_Hifonics-Brutus-BRZ2400.1D.html
a better choice from hifonics.
upgrading alt? depends on how big your stock one is. more than likely you wont be able to play full tilt while idling without risking damage to something.
0 gauge is a must. get rid of that cap cause its not gonna do shit.
you're gonna need the biggest agm battery you can fit under the hood, and a group 31 agm in the trunk near the amp.
What would be a good alt to get for this build? Factory alt is a 110amp, pretty low...
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
anything from mechman, dc power, singer, ohio
also there is a guy selling 2 12 Fi Q's on here. Probably cheaper than new
I saw them, it's an okay deal but I would rather just buy them new with a few of the options.. Plus my car is a blue/black scheme and there's no chrome on it etc so those dust caps.. Just nah lol..
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
The alt I can get from Stinger is about $500, what brand would be the best but still at a decent price? Looking to spend $300-$400 at the most.
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
If your going for a 400.4 and 3k mono
You'll need to look at
300amp alt
2x 0 runs from bat
2 bats in trunk
1 good bat up front
If you have issues or money is a big thing
I'd start with
300amp alt or as close to it as u can get
Start with 1 0g run
And 1 good bat up front
Then a second run of 0
Then 2 batts in rear
