Ok i'm kind of caught in a dilema, I get my car back in a month or two, and i need to know what i'm going to use for a system.
I have 4 12's
2 pioneers - 4ohm single voice coil - 800 watts max each and 150watts rms each
1 insignia - 4 ohm dual voice coil 1800 watts max and 600 watts rms
1 volfenhag - 4 ohm dual voice coil 2500 watts max and 1200 watts rms
I have 1 sony amp that is rated at # 1200W peak power
# 500W RMS (continuous) x 1 @ 4 ohms, bridged
# 250W RMS (continuous) x 2 @ 2 ohms
# 200W RMS (continuous) x 2 @ 4 ohms
I obviously do not want to run all 4 of these off of my amp. I was thinking of either wiring the insignia and volfenhag to 2 ohms and using just them.
The other option is using the 2 pioneers, i don't know if that would be a good choice.
When i run all these subs off of my home setup, the 2 pioneers are louder then the volfenhag and insignia put together for some reason.
I will most likely end up selling 2 of these subs and going with the other 2.
I would like some advice as to which 2 subs would be the best running off of this amp. Thanks. :)
or sell all of them and get 1 sub thats better then all of them put together?
^^^^^^^ what he said ;)
looking at what you got, nothing is going to give you the optimum output out of the system.
You could try and wire the amp down to 2 ohm and see how it does with either D4 sub. The amp may or may not like to be run in a lower ohm load.
I would try to pan your stuff off to friends and get different stuff. At least a different amp.
Keep the 2 pioneers and pawn the rest?
